2009-2011 Honda Pilot
Navigation Video Converter
by NavTool
Connects DVD, Back-Up Camera, TV, and other video sources to your O.E.M. navigation
FOR SALE ONLY NAVIGATION CONVERTER
NOT THE NAVIGATION SCREEN OR NAGIVATION BRAIN/DVD ROM
Connectors of the Interface
24-Pin Main Connector
Video input one is dedicated for any external composite video source.
Video input two is dedicated for back-up camera, input is automatically activated when vehicle is placed in reverse, parking grid lines can be turned on or off.
Video input two can also be used as an input for any external composite video source.
Video switching is done by pushing supplied push button switch, single push will cycle between Video 1 and Video 2, press and hold push button for more than 2 seconds to return back to the original navigation/information screen.
Plug and play T-Harness
Parking Brake Input +12V
Accessory input
Push Button Switch Input
Chassis Ground Connection
Composite Video 1 Input
+12V Reverse Light Input
Composite Video 2 Input
About This Item
NavRGB 2.0 is a new generation of navigation video interfaces that add video capabilities to vehicles with a factory installed navigation system, or with a color information screen.
NavRGB 2.0 does not replace or add a factory navigation system; it creates additional video inputs for the factory installed navigation system or color information screen.
NavRGB 2.0 + HA32 are 100% plug and play - no wire cutting required. NavTool plug and play installation harnesses are made using O.E.M. connectors.
NAVRGB 2.0 is an externally wired plug and play video interface that is installed in-line with the navigation computer and navigation screen. It works simply by interrupting the video signal from the navigation computer when it is activated, or when +12V are applied on the reverse camera wire. When this occur the navigation system video image will be replaced by the video source connected to NavRGB 2.0 video interface.
NAVRGB 2.0 is a video-only input interface and does not have any audio inputs. If the vehicle does not have a factory installed AUX audio jack, then an auxiliary audio input adapter or an audio FM modulator is needed to connect audio signals from an external Audio/Video source to the factory audio system.
NavRGB 2.0 is video-in-motion enabled for off-road use, so the video image will stay on the screen even while the vehicle is in motion, however we do not recommend doing this.
Factory navigation DVD-ROM cannot play DVD movies, external video source is needed to display video on the factory navigation screen. Examples of video sources: DVD player, Game Console, Digital Media Player, HDD, iPhone, iPad, iPod Video (NavRGB 2.0 does not support iPod Controls or iPod audio).
